Astrozap Glass Solar Filter. 124mm-130mm. Clear aperture 101mm [AZ-1514]
AZ-1514
$91.00 USD
Astrozap: Full Aperture Glass Solar Filter 124mm-130mm 4-7/8 to 5-1/8 diameter.
About Astrozap Glass Solar Filter. 124mm-130mm. Clear aperture 101mm [AZ-1514]
  • SKU    AZ-1514
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    4.1" - 6"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    5.25"
  • FILTER FITS TELESCOPE OD RANGE OF...    124mm to 130mm
