Baader H-alpha 50.4mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCHALN-RD50]
50.4 mm x 3 mm Baader H-alpha Narrowband Filter – Precision Grade 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5 Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies We explicitly warn against observing the sun with a DeepSky 6.5 nm (equivalent to 65 Ångstroem) H-alpha narrowband filter, specialized solar chromosphere and prominence filters from SolarSpectrum start at 0.8 Ångstroem. Photographic experiments with a camera are theoretically possible, but by no means observe the sun with naked eyes – you endanger your eyesight!
SKU 2961104
About Baader H-alpha 50.4mm Narrowband-Filter (6.5nm) – CMOS-optimized [BA-FCHALN-RD50]
Baader: Baader H-alpha 50.4mm Narrowband-Filter (6.5nm) – CMOS-optimized
- 50.4 mm x 3 mm Baader H-alpha Narrowband Filter – Precision Grade
- 6.5 nm FWHM, recommended for optical systems from f/10 to f/3.5
- Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies
SKU 2961104
- SKU (#) 2961104
- EAN CODE 4047825046956
- NET WEIGHT (KG) 0.07
- COLOUR Black
- TRANSMISSION RANGE H-alpha
- FILTER THICKNESS (WITHOUT CELL) 3 mm
- HBW (HALFBANDWIDTH) 6.5 nm
- CWL (CENTRAL WAVELENGTH) 656,3 nm
- AR-COATING Reflex-Blocker™ hard coated, planeoptically polished
- SPECIAL FEATURES CMOS-optimized with Life-Coat™
- FILTER SIZE 50.4 mm
- FILTER USAGE CMOS, CCD, H-alpha
- FILTER MOUNTED Unmounted
- TYPE OF FILTER Narrowband
- FILTER SHAPE round
