Astrozap Glass Solar Filter. 98mm-105mm. Clear aperture 90mm [AZ-1510]
AZ-1510
$91.00 USD
Astrozap: Full Aperture Glass Solar Filter 98mm-105mm 3-7/8 to 4-1/8 diameter, fits Meade ETX 90; Celestron: NexStar 60/80/80GT, FirstScope 90EQ; Orion: StarMax 90, Apex 90; StellarVue: NightHawk APLANAT, NightHawk Next Generation (with dew shield), SV809D (with dew shield); Questar 3.5.
About Astrozap Glass Solar Filter. 98mm-105mm. Clear aperture 90mm [AZ-1510]
  • SKU    AZ-1510
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    4.1" - 6"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    4.25"
  • FILTER FITS TELESCOPE OD RANGE OF...    98mm to 105mm
