Astrozap Glass Solar Filter. 92mm-98mm. Clear aperture 80mm [AZ-1509]
AZ-1509
$81.00 USD
2 in stock IN STOCK, usually ships within 48h or less directly from our Canadian warehouse
Astrozap: Full Aperture Glass Solar Filter 92mm-98mm 3-5/8 to 3-7/8 diameter, fits Celestron 80 (old);Meade DS-70, ETX-80 AT-TC Orion: ShortTube 80, Observer 70, Astroview 80/90, Explorer 80/90; Vixen: ED8sf, ED100sf.
About Astrozap Glass Solar Filter. 92mm-98mm. Clear aperture 80mm [AZ-1509]
  • SKU    AZ-1509
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    2" - 4"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    4"
  • FILTER FITS TELESCOPE OD RANGE OF...    92mm to 98mm
