Astrozap Glass Solar Filter. 86mm-92mm. Clear aperture 80mm [AZ-1508]
AZ-1508
$81.00 USD
Astrozap: Full Aperture Glass Solar Filter 86mm-92mm 3-3/8 to 3-5/8 diameter, fits Celestron FirstScope: 60 AZ & EQ, 80 EQ; Meade: ETX-60AT, ETX-70AT; Orion: Observer 60 Altaz & EQ Tele Vue-76, Tele Vue Pronto;Vixen: A80Mf, A80SSWT, ED81SWT.
About Astrozap Glass Solar Filter. 86mm-92mm. Clear aperture 80mm [AZ-1508]
  • SKU    AZ-1508
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    2" - 4"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    3.75"
  • FILTER FITS TELESCOPE OD RANGE OF...    86mm to 92mm
