Astrozap Glass Solar Filter. 79mm-86mm. Clear aperture 72mm [AZ-1507]
AZ-1507
$81.00 USD
Astrozap: Full Aperture Glass Solar Filter 79mm-86mm 3-1/8 to 3-3/8 diameter, fits Meade DS-80EC, DS 2080 StellarVue: NightHawk 80mm (with dew shield), SV80s;Tele Vue Ranger; Takahashi FC-50, FC-60, FC-60C;Williams Optics ZS66;Zeiss Telementor Refractor.
About Astrozap Glass Solar Filter. 79mm-86mm. Clear aperture 72mm [AZ-1507]
  • SKU    AZ-1507
  • MANUFACTURER    Astrozap
  • FILTER OD SIZE IN INCHES    2" - 4"
  • WARRANTY    1 Year Warranty
  • FILTER DIAMETER    3.50"
  • FILTER FITS TELESCOPE OD RANGE OF...    79mm to 86mm
