Astrozap Glass Solar Filter. 73mm-79mm. Clear aperture 60mm [AZ-1506]
About Astrozap Glass Solar Filter. 73mm-79mm. Clear aperture 60mm [AZ-1506]
Astrozap: Full Aperture Glass Solar Filter 73mm-79mm 2-7/8 to 3-1/8 diameter, fits Celestron 60; Meade DS-60 EC; Orion 70; Takahashi FS-60;Vixen A70Lf.
- SKU AZ-1506
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 2" - 4"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 3.25"
- FILTER FITS TELESCOPE OD RANGE OF... 73mm to 79mm
