Astrozap Glass Solar Filter. 60mm-67mm. Clear aperture 50mm [AZ-1504]
About Astrozap Glass Solar Filter. 60mm-67mm. Clear aperture 50mm [AZ-1504]
Astrozap: Full Aperture Glass Solar Filter 60mm-67mm 2-3/8 to 2-5/8 diameter, fits View Finders, Cameras, Small Refractors, Spotting Scopes, and Binoculars.
- SKU AZ-1504
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 2" - 4"
- WARRANTY 1 Year Warranty
- FILTER DIAMETER 2.75"
- FILTER FITS TELESCOPE OD RANGE OF... 60mm to67mm
