Astrozap Glass Solar Filter. 41mm-48mm. Clear aperture 38mm [AZ-1501]
This premium solar filter uses an aluminum cell as the frame- a cell that is meant to be smoothly attached to the end of your optical tube with nylon thumb screws and felt padding. These filters then make use of hand picked, thouroughly inspected optical glass of the highest quality available and coatings meant to ensure not only maximum reflectivity, but also the durability to last. These glass filters render the sun a natural-appearing orangeish hue, letting you see the sun in the pallet of hues we traditionally associate with the sun. The filter box is foam lined for protection and shock absorption during handling, and is durable enough to store the filter while not in use.
The Astrozap 41-48mm OD Full Aperture Glass Solar Filter is a premium quality solar filter available at an affordable price! These splendid filters allow you to make full use of your telescopes power due to their full aperture design, while remaining safe for solar use when handled properly. The Astrozap 41-48mm OD Full Aperture Glass Solar Filter is composed of hand picked and heavily inspected glass of the highest quality, manufactured in the USA and designed for safe and fun solar astronomy. The Astrozap 41-48mm OD Full Aperture Glass Solar Filter is sized with an OD of 41-48mm, making that the range of aperture that is optimal for scopes to make use of it. This makes this particular model of Astrozaps solar filter lines best for use with scopes like the older models of the Celestron Firstscope 60, view finders, cameras, other small refractors, spotting scopes, and even binoculars.
About Astrozap Glass Solar Filter. 41mm-48mm. Clear aperture 38mm [AZ-1501]
Astrozap: Astrozap has taken their excellent quality filter design into the solar field with stunning results! These full aperture white light solar filters are designed to provide the safest possible solar experience while still permitting the majority of safe light through for your enjoyment. The full aperture allows the most optimal daytime viewing possible so long as atmospheric turbulence remains minimal. One of the main benefits of full aperture filters like this is that they are designed to permit you to make use of the full aperture of the telescope they are attached to, avoiding any reduction of your field of view or other hindrances that might arise with other filter types, which obscure some of your telescopes original aperture. As a full aperture filter, Astrozaps premium glass solar filters utterly avoid that issue; letting you unleash your telescopes full power at the sun!
- The Astrozap 41-48mm OD Full Aperture Glass Solar Filter is a premium quality solar filter available at an affordable price! These splendid filters allow you to make full use of your telescopes power due to their full aperture design, while remaining safe for solar use when handled properly.
- The Astrozap 41-48mm OD Full Aperture Glass Solar Filter is composed of hand picked and heavily inspected glass of the highest quality, manufactured in the USA and designed for safe and fun solar astronomy.
- The Astrozap 41-48mm OD Full Aperture Glass Solar Filter is sized with an OD of 41-48mm, making that the range of aperture that is optimal for scopes to make use of it. This makes this particular model of Astrozaps solar filter lines best for use with scopes like the older models of the Celestron Firstscope 60, view finders, cameras, other small refractors, spotting scopes, and even binoculars.
- SKU AZ-1501
- MANUFACTURER Astrozap
- FILTER OD SIZE IN INCHES 2" - 4"
- WARRANTY 1 Year Warranty
