Astrozap Glass solar Filter Off Axis 265mm-272mm [AZ-1554-1]
265mm-272mm 10 3/8” (264mm) to 10 5/8” (270mm), fits Celestron 9 ¼ S-C, Celestron StarHopper 8" Dobsonian
About Astrozap Glass solar Filter Off Axis 265mm-272mm [AZ-1554-1]
Astrozap: Off Axis Glass Solar Filter
265mm-272mm |
