Avalon M-DUE - StarGo2 Pro - Special Price for Pre Order [AV-1MDU001]
2 in stock specialorder On sale Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
Description
The M-due Fast Reverse is a single arm fork mount devoted to deepsky imaging in the capacity range up to 25 kg in single telescope configuration and up to 32 kg in double telescope configuration.
The M-due design put together the M-uno and the M-zero mounts concepts, adding two very important features as the High Resolution ABSOLUTE ENCODER and the new StarGo2 Pro controller.
A robust mount base, an high payload capability and more then 6 positions available for the DEC arm on the RA axis. In this way it is possible to achieve the best balancing by using as less as counterweight possible.
HIGH RESOLUTION ABSOLUTE ENCODER ON BOTH RA/DEC AXIS
With the M-due mount, the Avalon Instruments exclusive Belt Drive System has been now improved by adding High Resolution ABSOLUTE ENCODER.
Slew Speed: up to 10° / sec
StarGo2 Pro
The mount is controlled by the new StarGo2 Pro, the controller comes with the following features:
Raspberry pi 4 based
Compatible with all the Linux astronomical software (Kstar, Stellarium, Carte du Ciel etc.)
4” Touch Screen Display on StarGo2 Pro case embedded
Connection mode:
- HARDWARE CONNECTION
- Mode 1: StarGo2 Pro as Hotspot
- Mode 2: StarGo2 Pro connected to your network, via LAN or Wi-Fi
- SOFTWARE CONNECTION
- Desktop remote connection to the StarGo2 Pro Operative System - Raspberry Pi4 - for a full setup control - mount, CCD cameras, focuser etc.
- Multiplatform Web App, for the system network connection and the mount function management
Standard Raspberry pi4 Input/Output:
- 2 HDMI ports, 1 audio port, 2 USB 2.0 ports.
- 2 USB 3.0 ports, 1 Ethernet port
- 2 x 12 volt power out ports
- 1 x variable 6 – 12 volts power out port
- 1 x Keypad
SkySafari direct connection
Driver:
- INDI (Linux, Mac O.S.)
- ASCOM Alpaca (Windowd O.S.)
Finally a real All in one astrophotografic setup management system for:
Mount - CCD cameras - Focuser
Dual Dec fully rotating axis
The M-Due comes with a fully rotating declination axis, which allows the use of a second clamp (optional) to hold a second OTA
CONTENT PACKAGE
Mount Head with StarGo2 Pro
T-Pod Plate
Second Telescope Adjustable System
StarGo2 Pro control Keypad
Keypad connection cable
Metric Allen Wrench key set
0,5 kg Counterweight with support shaft
Losmandy clamp
USB flash drive with manuals and software
Polar finder
Attachment screws
Documentation, warranty certificate
Power Supply
About Avalon M-DUE - StarGo2 Pro - Special Price for Pre Order [AV-1MDU001]
Avalon Instruments: M-due, Single Fork Equatorial Mount, with High Resolution ABSOLUTE ENCODER, StarGO2 Pro controller. Second Telescope Adjustable System with predisposition for second saddle.
Description
StarGo2 Pro
Connection mode:
- 1 x Keypad
Driver:
CONTENT PACKAGE
T-Pod Plate
Losmandy clamp
Polar finder
Attachment screws
Power Supply
Technical DataTable | |
Type | Single arm fork equatorial mount |
Encoder | High Resolution Absolute Encoder |
Weight | 22,4 kg |
Capacity | 25 kg single telescope setup, 32 kg double telescope setup. |
Transmission system |
All belts drive system based on four stages reducer. All the movements are on ball bearings. No maintenance and no backlash system. Pulleys made with special polymer fiberglass charged and high precision toothed belts. |
Construction Material | Anodized aluminium, worked out from single blocks with high precision 5 axis CNC machines |
Slew Speed | up to 10° / sec |
Polar Finder | Skywatcher model (optionally Losmandy model) |
GOTO system | StarGo2 Pro |
Counterweight bar | Dovetail 3" clamp |
Counterweight | 0,5 kg counterweight |
Scope plate | Losmandy, 3" (75mm), dovetail, single knob with 2 tightening points |
Warranty | 2 years from the purchase date, extended to 5 years for the transmission system |
