Avalon M-zeta Wi-Fi [AV-1MZT002]
AV-1MZT002
$5,208.51 USD
Avalon Instruments:
M-Zeta is the Avalon Instruments Azimuthal mount. Strong, accurate, easy to use and well designed the M-Zeta bring the Avalon Instruments concept of the Belt Driven System to an Azimuthal mount. The M-Zeta can manage OTAs up to 20kg/44lb, does not need counterweight and is ready to use in a few minutes.
Just connecting the StarGO Control System embedded on the DEC mount body to a pc via USB, WiFi or Bluetotooth (on depending of the StarGo model purchased), or just on a device such as Smartphone or tablet, the mount is ready to be used for an observation session.
CONTENT PACKAGE
Mount Head with StarGO GoTO control system Wi-Fi
Power Supply 15V/4 A
StarGO control Keypad
Keypad connection cable
Metric Allen Wrench key set
Losmandy clamp
USB flash drive with manuals and software
Attachment screws
Documentation, warranty certificate
T-Pod Plate
About Avalon M-zeta Wi-Fi [AV-1MZT002]
Avalon Instruments:
CONTENT PACKAGE
Losmandy clamp
Attachment screws
T-Pod Plate
Technical Data
Type
Altazimuth mount
12,2 kg (26,8 lb), without counterweight and bar
 Capacity
20 kg (44 lb)
 Transmission system
All belts drive system based on four stages reducer.
All the movements are on ball bearings. No maintenance and no backlash system.
Pulleys made with special polymer fiberglass charged and high precision toothed belts.
Construction Material
Anodized aluminium, worked out from single blocks with high precision 5 axis CNC machines
AR Axis
Heavy duty steel, diam. 35mm; 1 x dual ball bearings, diam. 62mm + 1 x roller bearing diam. 72mm + 2 x roller bearing diam. 45mm – On bearings clutch system
DEC Axis
Heavy duty steel, diam. 35mm; 1 x dual ball bearings, diam. 62mm + 1 x roller bearing diam. 72mm + 1 x roller bearing diam. 45mm – On bearings clutch system
GOTO system
StarGO GoTo Control System (WiFi or Bluetooth version)
Counterweight bar
No counterweight bar is required
Counterweight
No counterweight is required
Scope plate
Losmandy, 3" (75mm), dovetail, single knob with 2 tightening points
Warranty
2 years from the purchase date, extended to 5 years for the transmission system
