Avalon M-zero obs Bluetooth (Special Price) Motorized Polar Alignment included [AV-1MZR008]
Your next backyard mount
The new M-zero obs is the perfect solution for a backyard, personal, customized observatory.
NOTE: Motorized Polar Alignment are optional, to be purchased must be selected on the drop down menù below.
NOTE: If the version with the optional Motorized Polar Alignment kit it will be purchased, please notify in the “Notes and special request” field in the shopping cart, the latitude range where the mount wish to be used.
PACKING CONTENT
Mount Head
Aluminium anodised Pier
Transport bag
Counterweight rod
StarGO Keypad
0.5 kg Counterweight
Polar scope with support
Power Supply 15V/4 A
Warranty & Testing Certificates
Declaration of Conformity
Allen wrench
Tripod plate and screws for fixing the mount to the tripod
USB flash drive with manuals and software
Ra/Dec motor cables
Dual Dec adapter
Description
Small overall dimensions
With the same M-zero standard version smart and compact design, the M-zero obs comes with very small overall dimensions (72 x 64 x 60 cm), in this way it is possible to place the full equipment in a very small observatory.
The M-zero obs comes already provided with the HQ stepper motors, as well as the M-zero HQ, to achieve the best performance possible in tracking.
The well known M-zero reliability and versatility allow to equip on the mount many different setup, double telescope setup included.
No Meridian Flip
The M-zero obs, as well as the M-zero standard version and the M-uno, allow the very helpful No Meridian flip feature.
Two main configuration: one telescope setup, double telescope setup
Among the many setup possible with the M-zero obs, there are two main configuration: the one telescope setup and the double telescope setup. The first one is more suggested for those who wish to use the mount inside an observatory, the second is suggested as a portable setup.
One telescope setup (better for small observatory)
This configurations is suitable for a small customized observatory, the StarGo board can be assembled on the bottom side of the DEC arm, in this way it can be also considered as an "extra counterweight". In this way, with small refractor, the mount can be also balanced without any counterweight. The telescope can track all night long, without the need of the Meridian Flip, without any collision risk.
Double telescope setup (optimized for portable/stable backyard configuration)
The double telescope configuration has been optimized for the portable setup or a stable backyard configuration
In this way it will be possible to fully use the second telescope.
Thanks to the high quality materials (anodised aluminium and stainless steel), the mount can be left outside for long time, by using a simple cover, to prevent rain/humidity/weather damage.
In this way it will be possible to have several sessions and, thanks to the PARK/UNPARK StarGo GoTo System feature.
With this configuration the StarGo board can be assembled directly on the pier, in this way any second telescope collision risk will be prevented.
Optional Motorized Polar Alignment
The optional Motorized Polar Alignment allow a full remote control, in this way, once the setup has been done, it will be possible to perform an accurate remote Polar Alignment.
About Avalon M-zero obs Bluetooth (Special Price) Motorized Polar Alignment included [AV-1MZR008]
Avalon Instruments:
PACKING CONTENT
Mount Head
Transport bag
Counterweight rod
StarGO Keypad
Allen wrench
Ra/Dec motor cables
Dual Dec adapter
Description
No Meridian Flip
