Transport bag Medium [TTS-2664]
0 in stock specialorder
The transport bags are made from black and orange neoprene. The bottom of the cylinder shaped bags is covered with a water and dirt resistant material keeping the bags nice and clean even after field trips. The neoprene foam layer protects the mount parts without taking up any extra space. This is possible because the mount parts has been designed to have no protruding parts that can be damaged during transport.
The double handles carries the bags even with big weight loads.
Find the bag you need
Below you can select bags for the different mount parts. The bags are also perfect for transporting and storing other equipment. See the bag sizes under “Specifications” tab.
About Transport bag Medium [TTS-2664]
Track the stars: Compact and safe transport of equipment
| Bag Size | 4 kg Counterweight set | 8 kg Counterweight set | Handpad | Telescope rOTAtor | Pier extension | Mount Head | Folding Pier | Mini Pier |
| Large | X | X | ||||||
| Medium | X | X | X | |||||
| Small | X | X | X |
FREE - [zp] heavy/oversize - contact us for cost (scheduled delivery)
