Side mount dovetal saddle Vixen Size [TTS-160S]
TTS-160S
$151.32 CAD
Track the stars: Installation of the saddle
This Vixen size dovetail saddle is easily installed on the counterweight arm with two screws. The magnetic holder for the handpad must be removed first.  Adjustment of the telescope pointing must be done on the telescope tube rings.
NOTE: Not all versions of the Panther mount has the necessary tapped holes for mounting the saddle. Check your mount before ordering – contact us for details.
Capacity of the Vixen dovetail saddle
The saddle will carry telescopes ud to 10kg in parallel with a telescope mounted on the normal top dovetail saddle. It is possible to install telescopes on both arms at the same time. Be aware of the total capacity of the mount head.
About Side mount dovetal saddle Vixen Size [TTS-160S]
Materials
Aluminium
Telescope Capacity
10 kg -less for large aperture telescope
Dovetail Size
Vixen style dovetail: Width 43.5mm, side angles 12 degrees
Specifications
