Panther Counter weights 2 x 4 kg, including transport bag [TTS-160C]
0 in stock specialorder
Balancing extra equipment
If you install a piggyback camera or guide telescope it’s very easy to balance again just by lovering the counterweights. No need for extra tube mounted counterweight as needed on German Equatorial Mounts.
About Panther Counter weights 2 x 4 kg, including transport bag [TTS-160C]
Track the stars: Easy balancing With the azimuth axle being vertical there is only the altitude axle to balance on Track The Stars Mounts. The counterweight can easily be positioned and fixed on the counterweight arms. Just release the altitude clutch and feel the balance and adjust the counterweight position.
FREE - [zp] heavy/oversize - contact us for cost (scheduled delivery)
