MicroLine ML16803 Monochrome CCD Cooled Camera KAF-16803 with 65mm Shutter & Standard Heatsink [FLI-ML16803STDHS]
FLI-ML16803STDHS
$12,379.85 USD
Flight Lakes Instrumentation: MicroLine ML16803 Monochrome CCD Cooled Camera KAF-16803 with 63.5mm Shutter  - 4096 x 4096 Imaging Array 9 μm Pixel Size
About MicroLine ML16803 Monochrome CCD Cooled Camera KAF-16803 with 65mm Shutter & Standard Heatsink [FLI-ML16803STDHS]
