Parallax 13" OD Tubes (Celestron RASA) [PA-ODT13]
PA-ODT13
$349.20 USD
Parallax Instruments: Parallax - Parallax 13" OD Tubes (Celestron RASA)
These 13" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 13" OD Tubes (Celestron RASA) [PA-ODT13]
