QSI 6162 Model 16 megapixel full frame CCD [QSI-6162]
QSI-6162
From $7,064.95 USD
QSI- The QSI-6162 model camera model employs a KAF-16200, 16 megapixel, full frame CCD image sensor with microlens technology that has been specifically produced for astrophotography. The 6-micron pixel size make this camera the ideal imaging partner for a wide range of focal length telescopes. The ability to ‘bin’ the CCD means the QSI-6162 is suitable for focal lengths right up to 2.5m and still stay around 1 arc second per pixel (recommended for successful imaging). The large APS-H 16mp CCD sensor with a 35mm diagonal works happily using 2” mounted or 50.8 mm unmounted filters on scopes as fast as f/2.8 with minimal vignetting. The camera is available with or without an Off-Axis Guider and the choice of a five or eight position filter wheel.
The ‘ws’ model comes with a shutter and filter wheel installed. The ‘wsg’ model is supplied with the Off-Axis Guider, Integrated Guider Port (IGP).
The 6162 camera system is supported by industry leading image acquisition software plus a full camera control API is available for creating custom Windows or Linux applications.
  • Select your QSI 6162 model.
About QSI 6162 Model 16 megapixel full frame CCD [QSI-6162]
Model QSI-6162 Specifications
Specifications
Sensor Type CCD – KAF-16200
Horizontal Resolution 4499 pixels
Vertical Resolution 3599 pixels
Pixel Size 6 µm x 6 µm
ADC 16 bit
Readout Noise 8e- typical value high quality mode
Gain Factor High gain and low gain modes
Full Well ~40,000e-
Dark Current >0.25 electrons/second at 0°C
Interface USB 2.0 high speed
Power 12v DC 3.5A
Maximum Exposure Length Unlimited
Minimum Exposure Length 50 ms
Cooling Thermoelectric set point with max ΔT -50°C
Download speed High speed 3 seconds
High quality 23 seconds
Weight: approx. 2.9 kg for wsg-8
2.8 kg for ws -8
OAG weight 0.15kg
Dimensions 5 pos: 189 x 189 x 87.5mm
8 pos: 238 x 238 x 87.5mm
Back Focus Standard all models – 31 mm (38 mm with front plate adaptor)
Optional wsg add on – 51 mm (61 mm with front plate adaptor)
Optional low profile – 31 mm (35mm with front plate adaptor) for use with Canon/Nikon lens adaptors
Adapter threads currently M54 x 0.75 mm, standard all models
Optional wsg add on, M68 x 1 mm internal thread
External  3” connection to fit standard 3” draw tube
In the box Power adaptor
Custom case
USB cable
USB drive with software
M54 to 2” eyepiece adaptor
