Baader S-II 50x50mm f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-SQ50]
BA-FCSIIHS-SQ50
$510.40 CAD
Baader: Baader S-II 50x50mm f/2 Highspeed-Filter (6.5nm) – CMOS-optimized
50 x 50 mm x 3 mm Baader S-II f/2 Highspeed Filter – Precision Grade 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8 Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies SKU 2961305
About Baader S-II 50x50mm f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-SQ50]
  • 50 x 50 mm x 3 mm Baader S-II f/2 Highspeed Filter – Precision Grade
  • 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8
  • Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs
SKU 2961305
  • SKU (#)    2961305
  • EAN CODE    4047825047526
  • NET WEIGHT (KG)    0.07
  • COLOUR    Black
  • TRANSMISSION RANGE    S-II
  • CWL (CENTRAL WAVELENGTH)    671,7 nm
  • FILTER SIZE    50 x 50 mm
  • FILTER USAGE    CMOS, CCD, S-II
  • FILTER MOUNTED    Unmounted
  • TYPE OF FILTER    f/2 Highspeed
  • FILTER SHAPE    square
