Baader S-II 50.4mm f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-RD50]
BA-FCSIIHS-RD50
$299.00 USD
Baader: Baader S-II 50.4mm f/2 Highspeed-Filter (6.5nm) – CMOS-optimized
50.4 mm x 3 mm Baader S-II f/2 Highspeed Filter – Precision Grade 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8 Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies SKU 2961304
About Baader S-II 50.4mm f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-RD50]
  • 50.4 mm x 3 mm Baader S-II f/2 Highspeed Filter – Precision Grade
  • 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8
  • Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs
SKU 2961304
  • SKU (#)    2961304
  • EAN CODE    4047825047519
  • NET WEIGHT (KG)    0.07
  • COLOUR    Black
  • TRANSMISSION RANGE    S-II
  • CWL (CENTRAL WAVELENGTH)    671,7 nm
  • FILTER SIZE    50.4 mm
  • FILTER USAGE    CMOS, CCD, S-II
  • FILTER MOUNTED    Unmounted
  • TYPE OF FILTER    f/2 Highspeed
