Baader S-II 2" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-2]
2" x 2 mm Baader S-II f/2 Highspeed Filter – Precision Grade – with 2" (M48) filter thread 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8 Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies Mounted in Baader Low Profile Filter Cell (LPFC) – 6 mm height SKU 2961303
About Baader S-II 2" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-2]
Baader: Baader S-II 2" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized
- 2" x 2 mm Baader S-II f/2 Highspeed Filter – Precision Grade – with 2" (M48) filter thread
- 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8
- Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs
- Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies
- Mounted in Baader Low Profile Filter Cell (LPFC) – 6 mm height
SKU 2961303
- SKU (#) 2961303
- EAN CODE 4047825047502
- NET WEIGHT (KG) 0.07
- COLOUR Black
- TRANSMISSION RANGE S-II
- HBW (HALFBANDWIDTH) 6.5 nm
- CWL (CENTRAL WAVELENGTH) 671,7 nm
- AR-COATING Reflex-Blocker™ hard coated, planeoptically polished
- SPECIAL FEATURES CMOS-optimized with Life-Coat™
- FILTER SIZE 2 inch
- FILTER USAGE CMOS, CCD, S-II
- TYPE OF FILTER f/2 Highspeed
- FILTER SHAPE round
