Baader S-II 1¼" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-1]
BA-FCSIIHS-1
$174.00 USD
Baader: Baader S-II 1¼" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized
1¼" x 2 mm Baader S-II f/2 Highspeed Filter – Precision Grade – with 1¼" (28,5 mm) filter thread 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8 Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs Reflex-Blocker™ hard coated and planeoptically polished – with sealed coating edges (Life-Coat™) Blackened edges all around, with filter-lead-side-indicator in the form of a telescope-sided black outer rim Optimized for modern CMOS cameras, but likewise excellent for CCD camera technologies Mounted in Baader Low Profile Filter Cell (LPFC) – 6 mm height SKU 2961300
About Baader S-II 1¼" f/2 Highspeed-Filter (6.5nm) – CMOS-optimized [BA-FCSIIHS-1]
  • 1¼" x 2 mm Baader S-II f/2 Highspeed Filter – Precision Grade – with 1¼" (28,5 mm) filter thread
  • 6.5 nm FWHM, recommended for extremely fast optical systems from f/3.4 to f/1.8
  • Specially designed for the special filter requirements when used with fast optics like the Celestron RASA astrographs
  • Mounted in Baader Low Profile Filter Cell (LPFC) – 6 mm height
SKU 2961300
  • SKU (#)    2961300
  • EAN CODE    4047825047472
  • NET WEIGHT (KG)    0.06
  • COLOUR    Black
  • TRANSMISSION RANGE    S-II
  • CWL (CENTRAL WAVELENGTH)    671,7 nm
  • FILTER SIZE    1 25 inch
  • FILTER USAGE    CMOS, CCD, S-II
  • TYPE OF FILTER    f/2 Highspeed
