Pegasus Astro EQDIR USB Stick DB9 [PEG-EQDIR-USB-DB9]
PEG-EQDIR-USB-DB9
$54.07 CAD $72.09 CAD
Pegasus Astro: EQDIR USB Stick for EQMOD
Our new compact EQDir USB Stick Adapter for EQMOD allows direct connection of Skywatcher HEQ5 Syntrek/PRO, NEQ6 Syntrek/PRO, AZ EQ6-GT and EQ8 mounts to your PC or laptop. With this adapter you can remote control your Skywatcher mount directly via PC. No handbox controller is needed and the device is perfect for remote observatories.
EQDIR heart is based on FTDI USB to Serial Chip
The device uses an original FTDI chip. This chip is fully compatible and functional with Windows XP, 7 , 8, 10, OSX, Linux. There is no need to install external drivers as Windows Update will install the latest FTDI driver. Just plug it in your PC and play.
EQDIR adapter for DB9 Mounts)
Choose the appropriate model (DB9 or RJ45) for your mount model. You can use the same device in both of your mounts. Just attach the adapter RJ45 to DB9 and you are ready to go.
Compact size
It is a just USB Stick
About Pegasus Astro EQDIR USB Stick DB9 [PEG-EQDIR-USB-DB9]
Compact size
Mount Connector RJ45
PC Connector (USB Model only) USB type A (PC Stick)
Length  2 meters
Cable to mount RJ45 to RJ45 or RJ45 to DB9
Dimensions USB Stick
