Pegasus Astro Hand Controller for FocusCube [PEG-FC2-HC]
PEG-FC2-HC
$73.40 USD
Pegasus Astro:
Hand Controller of the FocusCube allows manual focus with precision and without vibrations!
This Hand Controller is suitable only for the Pegasus FocusCube. Do not plug it in any other Pegasus Astro product as you may damage both devices.
Digital Encoder with a Push button
The rotary knob simulates the knob of your focuser. Rotate the digital knob and easily focus! Precision can be achieved if you press the knob inside. Speed is reduced to 1:10 just like the fine focus knob of your focuser!
Can work simultaneously with the PC operation
Just plug the hand controller in the auxiliary port of the FocusCube and enjoy precision in manual focusing without vibrations. No need to remove the hand controller when you use your PC to control the FocusCube. Both can work in parallel.
A LED indicator for each speed
On top of the RJ45 socket there are two LEDs. Green and Yellow indicate current speed: coarse or fine focus.
IN THE BOX
1 x Hand Controller for FocusCube
1 x RJ45 to RJ45 Cable
About Pegasus Astro Hand Controller for FocusCube [PEG-FC2-HC]
Pegasus Astro:
IN THE BOX
