Pegasus Astro Motor Focus Kit v2 Celestron SCT C14'' , Edge, RASA 14" [PEG-MFKV2-SCT14]
PEG-MFKV2-SCT14
$187.31 USD
Pegasus Astro: Motor Focus Kit v2 Celestron SCT C14'' , Edge, RASA 14"
Focus accurate and fast your Celestron SCT telescope using our powerful motor focus kit SCT. This high resolution geared box has a 0,06 degree step size can can easily lift more than 6 Kg (per cm). Its high torque is suitable for lifting heavy imaging equipment. Moreover motor’s gearbox has a low backlash which can easily tuned using backlash compensation in imaging software. An RJ45 socket pinout can be easily converted to a compatible pinout with Moonlite and Robofocus controllers.
Pulley and Belt design allows the motor to stay away from your filter wheel (and not collide with it) when you use a focal reducer. Its sophisticated bracket design can fit to all Celestron SCTs
Note: You will need a stepper controller to drive the motor. Check our Dual Motor Focus Controller
Following image is from the older plastic enclosure but it helps to understand how the SCT enclosure is attached on the telescope
A special shaped blue anodised aluminium bracket, hard to bend, can be attached to all Celestron SCT telescopes. We have successfully installed it on:
Celestron EdgeHD 8, 9.25 , 11, 14
Celestron SCT C6, C8, C925, C11, C14
Celestron RASA
What the Motor Focus Kit SCT package includes:
High resolution geared stepper motor (Step Angle 7.5, Deg 120, Gear Ration 1:120). Its gearbox has very low backlash and high torque suitable to focus in micron scale.
Blue Aluminium Anodised Bracket for Celestron SCT Telescopes
20cm 2GT Timing Belt
13 mm Pulley 2GT (6”,8”,9.25”) or 22mm Pulley 2GT (11” ,14” Celestron)
Bolts
About Pegasus Astro Motor Focus Kit v2 Celestron SCT C14'' , Edge, RASA 14" [PEG-MFKV2-SCT14]
Celestron RASA
Bolts
Pegasus Stepper Motor Technical Specifications
Step Angle (Deg) 7.5 / 120  = 0.0625
Gear Ratio 1:120
Phases 4 (Unipolar Motor)
Voltage 12V DC
Current (A) 0.27
Pull-in Rate (PPS) 400
Pull-in Torque (N.cm) 60 (100pps)
Weight Stepper Motor, SCT Adapter & Motor Pulley / Belt  weight in total 300g
