Pegasus Astro Motor Focus Kit v2 (Universal) [PEG-MFKV2-UNIV]
PEG-MFKV2-UNIV
$148.08 USD
Pegasus Astro:
Focus accurate and fast your telescope using our powerful Motor Focus Kit v2. This high resolution geared box has a 0,06 degree step size can can easily lift more than 6 Kg (per cm). Its high torque is suitable for lifting heavy imaging equipment. Moreover motor’s gearbox has a low backlash which can easily tuned using backlash compensation in imaging software. The RJ45 socket can be converted to compatible Robofocus Pinout.
Note: You will also need a stepper controller to drUniversal L Shaped Bracket (Black Anodisation)
A L shaped black anodised aluminium bracket, hard to bend, has cut rails and can be attached to a wide range of focusers. In fact we have successfully installed it on:
Orion Optics UK default focuser
GSO (RC focuser)
Takahashi (FSQ106, FSQ85)
Moonlite (2”, 2.5”)
Baader (Steel track)
Synta Focuser Refractors
Altair Astro (2”, 2.5”, 3”)
Starlight Focusers (2”, 2.5”, 3”, 3.5”)ive the motor. Check our Dual Motor Focus Controller
What the Motor Focus Kit package includes:
High Resolution Stepper Geared Motor Enclosure (Step Angle 7.5, Deg 120, Gear Ration 1:120). Its gearbox has very low backlash and high torque suitable to focus in micron scale.
Universal Black Anodised Aluminium L shaped bracket for Motor
6 x Solid Motor Couplers (3mm to 8mm)
Different sizes of bolts and spacers
About Pegasus Astro Motor Focus Kit v2 (Universal) [PEG-MFKV2-UNIV]
Pegasus Astro:
GSO (RC focuser)
Moonlite (2”, 2.5”)
Pegasus Stepper Motor Technical Specifications
Step Angle (Deg) 7.5 / 120  = 0.0625
Gear Ratio 1:120
Phases 4 (Unipolar Motor)
Voltage 12V DC
Current (A) 0.27
Pull-in Rate (PPS) 400
Pull-in Torque (N.cm) 60 (100pps)
Weight Stepper Motor, Universal L Shaped Adapter & Motor Coupler weight in total 300g
