Baader UHC-S L-Booster Filter 36mm Round [BA-FUHC-RD36]
Planeoptically Polished
Planeoptically polished for the highest images quality. Produces a much brighter image with superb contrast than a conventional Nebula filter. Excellent for openings from 100mm.
Baader UHC-S Nebula Filter with highest transmission and realistic star colours!
A new class of LPR Nebula filters finally delivering the happy medium, with enough light for smaller telescope openings at the same time with the high contrast of classical UHC filter.
Light pollution from street lights is blocked carefully. The filter is the sensible addition to all previous deep sky and UHC filters. Both for visual as well as photographic use.
All filters produce a brighter image and are optically polished with ultra-hard dielectric coatings. They are absolutely scratch resistant and can be cleaned as often as needed, ideally with Baader Optical Wonder Cleaning Fluid.
All Baader UHC-S DeepSky Filter
1¼", 2", 50.4 mm, 50x50 mm
ref baader : 2459420
About Baader UHC-S L-Booster Filter 36mm Round [BA-FUHC-RD36]
Baader: 36mm Baader UHC-S DeepSky Filter
MANUFACTURER | Baader Planetarium |
SKU (#) | 2459420 |
WEIGHT (KG) | 0.025 |
TRANSMISSION RANGE | multiple bands (see spectral image) |
FILTER THICKNESS (WITHOUT CELL) | 2 mm |
AR-COATING | dielectrically coated, planeoptically polished |
FILTER SIZE | 36 mm |
FILTER USAGE | Contrast Enhancement, Light Pollution Reduction, Luminance |
FILTER MOUNTED | Unmounted |
TYPE OF FILTER | Bandpass |
SINGLE OR SET? | Single Filter |
FILTER SHAPE | round |
