SESTO SENSO 37mm adapter [PRI-SESTOSENSO-AD37]
PRI-SESTOSENSO-AD37
$86.70 USD
PrimaluceLab: This 37mm adapter allow you to install SESTO SENSO on focusers that come with 37mm diameter large shaft, like the 3,5" FeatherTouch and FSQ-130 (or other focusers with 37mm diameter large shaft). SESTO SENSO as standard connects to focusers that comes with 25mm diameter shaft (that are the most of the focusers on the market): in order to connect it to focusers that comes with 37mm diameter large shaft, you need to add this adapter.
About SESTO SENSO 37mm adapter [PRI-SESTOSENSO-AD37]
