SESTO SENSO 2 33mm adapter [PRI-SESTOSENSO-AD33II]
$77.52 USD
2 in stock specialorder Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
PrimaluceLab: This 33mm adapter allow you to install SESTO SENSO 2 on focusers that come with 33mm diameter large shaft, like the 2,5" and 3" FeatherTouch (or other focusers with 33mm diameter large shaft). SESTO SENSO as standard connects to focusers that comes with 25mm diameter shaft (that are the most of the focusers on the market): in order to connect it to focusers that comes with 33mm diameter large shaft, you need to add this adapter.
About SESTO SENSO 2 33mm adapter [PRI-SESTOSENSO-AD33II]
