EAGLE CORE - control unit for astrophotography with DSLR camera [PRI-EAGLECORE]
PRI-EAGLECORE
$304.98 USD
PrimaluceLab:
Do you want to take pictures of galaxies, nebulae and star clusters like an expert but you don't want to use a computer for long exposure astrophotography with your Canon or Nikon DSLR camera? Switch to EAGLE CORE and combine the high performance of an astrophotography telescope with ease the use of a star tracker! Forget uncomfortable computers, drivers to install and complicated capture softwares, with EAGLE CORE DSLR astrophotography is fast and easy! Combining a capture and autoguiding software that you control via Wi-Fi from your smartphone or tablet to the innovative power system, you no longer need computers and heavy batteries. All in a Plug-and-Play device very easy to use even for those without experience!
DSLRs are great astrophotography cameras (even for long exposures of deep-sky objects such as galaxies, nebulae or star clusters) since they have high sensitivity and low noise, so they are able to record very weak details. Just use an equatorial mount with autoguide port and EAGLE CORE will allow you to record wonderful images of the objects of the Universe both using photographic lenses and telescopes! Thanks to EAGLE CORE, your instrument will have the high performance of an astrophotography telescope but with the portability and ease of use of a star tracker.
Compared to EAGLE2, that thanks to Windows operating system and the ability to install any astrophotography software is perfect for the astrophotographer that wants to make advanced astrophotography, EAGLE CORE is designed for those who start to do astrophotography and are searching for a very simple to use system or for those who want an easily transportable system as "travel telescope".
In order to make high quality astrophotography, connecting a DSLR to the telescope is not enough. It is necessary to be able to set and shoot the camera without touching it to avoid vibrations while recording and use the autoguide to automatically correct normal tracking errors of equatorial mounts. When using an external computer, telescope becomes complicated because of many cables or power supplies, it is less portable and it is necessary to study the capture and guide software. EAGLE CORE simplifies both your telescope and software, making your instrument easier to use and transport.
As for other EAGLE control units, EAGLE CORE is installed directly on your telescope, it powers the elements of your telescope (12V, up to 3 instruments) and it has a modular PLUS case allowing you to install it on all telescopes and to personalize your configuration as you prefer. It has also been designed to allow you to do long exposure astrophotography even with telephoto lenses thanks to a special shooting mode with the guide scope positioned at the telephoto lens side (see photo below).
In order to use EAGLE CORE together with a telephoto lens (and guide scope in parallel) you have to add "140mm PLUS dovetail bar" to be connected under EAGLE CORE body, in order to install everything on the equatorial mount. In the upper part the Eagle Core has a 1 1/4" photo thread to connect a photo ball head and then the camera. If you have an heavy photo lens (for example with focal length higher than 200mm) you can add the "PLUS Vixen+Losmandy dovetail clamp". Then you can connect the "PLUS 90mm Vixen dovetail bar" under the camera and then connect everything in the dovetail clamp. The guide scope is installed, using the optional 80mm PLUS guide rings and PLUS raisers, to be fixed on the side of EAGLE CORE.
In order to use EAGLE CORE with a telescope (and guide scope in parallel) you can connect it in many different ways and it's compatible with all the telescopes on the market: you can fix it on top of PLUS support rings (for example when you use a refractor) or you can add the dovetail clamp Vixen+Losmandy PLUS and connect to any Vixen or Losmandy style bar. Above EAGLE CORE body you can connect PLUS guide rings with guide scope (where to insert the guide camera).
WHAT YOU CAN DO WITH THE EAGLE CORE:
- Control DSLR and guide camera from your smartphone or tablet with a convenient WiFi connection: you will be able to see in real time pictures of guide stars or of the object recorded by your DSLR camera
- Remotely control your Canon EOS or Nikon DSLR camera: set acquisition parameters, then start capturing a single image or a sequence. These are the cameras already tested and verified with EAGLE CORE:
- Canon EOS 1000D, 1300D, 450D, 500D, 550D, 600D, 650D, 700D, 750D, 800D, 20D, 40D, 60D/60Da, 70D, 80D, 7D, 6D, 5D Mark III, 5D Mark IV
- Nikon D3300, D3400, D5300, D5600, D7000 (D7000 can't "B" mode), D600, D610, D750, D800E, D810
- Focus your DSLR camera: thanks to a special simplified mode, you can focus on the smallest details of your image, moving the focuser manually and remotely thanks to SESTO SENSO, the robotic focusing motor (optional).
- Remotely control autoguide camera: thanks to the integrated autoguide software, it automatically corrects tracking errors of the telescope's mount (compatible with QHY5II-L, ASI120MM-S, ASI120MC-S, ASI178MM, ASI290MM, ASI290MC and Lodestar)
- Use dithering: in order to minimize electronic noise and get a better image when you stack more pictures of the same object (* feature available soon, it will be added with a software update)
- Power up to 3 devices (12V): thanks to optional cables and adapters, you can power the DSLR camera, the mount, etc directly from the EAGLE CORE eliminating the need for other batteries and other external power supplies.
EAGLE OS: INTEGRATED SOFTWARE FOR DSLR ASTROPHOTOGRAPHY
Thanks to EAGLE CORE you will no longer need a laptop: in fact it includes EAGLE OS software to control autoguide and DSLR camera. You can control all capture and guide parameters directly on the screen of your smartphone or your tablet (compatible with iOS and Android devices) connected to EAGLE CORE through the convenient WiFi connection.POWER OUT PORTS TO BETTER ARRANGE CABLES CONNECTED TO THE TELESCOPE
Thanks to the innovative design protected by international patent application and Italian utility model, EAGLE CORE has 3 power OUT ports that you can connect (using the optional cables) to different devices such as camera or mount. In this way you will have only one power cable to power EAGLE CORE and other devices and you will reduce not only total consumption but also the number of cables in your instrument. You can also use the optional "Eagle-compatible power cable for Canon EOS and Nikon DSLR camera" to power them from EAGLE CORE (removing the battery you will no more have problems with batteries running out of charge during capturing!).
DESIGN: INNOVATION IN A COMPACT AND LIGHTWEIGHT DEVICE
All the incredible features of EAGLE CORE are enclosed in a compact, lightweight device with the great PrimaLuceLab design. EAGLE CORE case is made of aluminum blocks that are high precision CNC machined. The aluminum is then sandblasted to achieve a very smooth surface finish and is anodized (hard anodizing) to increase the hardness of the material and protect it from oxidation. EAGLE CORE weights only 520 grams so it does not add too much weight on your telescope mount and allows you to create an incredibly portable setup. All in a device 17cm long, 8cm wide and just 3cm thick.
EAGLE CORE comes with an astrophotography introduction user manual (in english and italian) that not only shows how to use EAGLE CORE but also teach the basics of astrophotography like how to properly set the equatorial mount, what is the autoguide and how to set it properly, why stacking more pictures together, etc. For esample, here you have part of the user manual:
Introduction to astrophotography with DSLR and mirrorless cameras
Planetary/lunar and deep-sky astrophotography
Astrophotography with telephoto lens or telescope?
Mount and sky objects tracking
Connecting DSLR or mirrorless camera to telescopes
Before starting to photograph: light pollution and power
Start taking pictures, step by step guide
Step 1: align the mount to Pole
Step 2: align the mount to the stars
Step 3: point the object to record
Step 4: focus DSLR or mirrorless camera
Step 5: start the autoguide
Step 6: advanced autoguide settings (optional)
Step 7: record pictures with DSLR or mirrorless camera
About EAGLE CORE - control unit for astrophotography with DSLR camera [PRI-EAGLECORE]
PrimaluceLab:
scope of delivery:
- EAGLE CORE control unit
- Power cable with cigarette plug for Eagle (length 200cm)
- 4 M6x8 screws, 4 M6x12 screws
- User manual with introduction to DSLR astrophotography (english and italian language)
