12V power cable with banana plugs for Eagle - 250cm [PRI-PL1000028]
PRI-PL1000028
$45.90 USD
PrimaluceLab: 12V power cable with cigarette plug for Eagle - 250cm
In order to power the Eagle (which in turn can power all other connected devices) you can use a battery or an A/C power supply. If you already have a battery of sufficient capacity, you can connect to Eagle with this 12V power cord. On the one side it has the Eagle screw connector, on the other one it has banana connector.
About 12V power cable with banana plugs for Eagle - 250cm [PRI-PL1000028]
