12V AC adapter for EAGLE - 5A [PRI-PL1000025]
PRI-PL1000025
$45.90 USD
PrimaluceLab: 12V power cable with cigarette plug for Eagle - 250cm
If you want to power EAGLE (that can power all other connected devices) and use it from a fixed station such as an observatory, you can connect it to an AC adapter power supply. This 12V power supply comes with a screw connector for EAGLE on one side and a plug for the socket on the other (compatible with 100 to 240V).
The AC adapter for EAGLE is available in two versions: 5A and 12A. Choose the one that best suits your needs based on the power requirements of accessories that are powered by EAGLE.
About 12V AC adapter for EAGLE - 5A [PRI-PL1000025]
