12,8V AC adapter for EAGLE - 12A [PRI-PL1000057]
PRI-PL1000057
$127.50 USD
4 in stock specialorder Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
PrimaluceLab: 12V power cable with cigarette plug for Eagle - 250cm
The 12,8V AC adapter for EAGLE  - 12A" (PL1000024) has been replaced by the new "12,8V AC adapter for EAGLE  - 14A” (PL1000057) that is able to provide even more Amps, it comes with longer cords and better adapters for EU, UK and USA plugs.
If you want to power EAGLE (that can power all other connected devices) and use it from a fixed station such as an observatory, you can connect it to an AC adapter power supply. This 12V power supply comes with a screw connector for EAGLE on one side and a plug for the socket on the other (compatible with 100 to 240V).
The 12A version has a slightly higher voltage (12.8V instead of the standard 12V) because when you are powering from the EAGLE many accessories with high current consumption, you can see a slight decrease in voltage which, in this way, it is perfectly balanced.
About 12,8V AC adapter for EAGLE - 12A [PRI-PL1000057]
