ZWO ASIAIR PRO [ZWO-ASIAIR-PRO]
ZWO-ASIAIR-PRO
$303.00 USD
ZWO Optical: Product Description
ASIAIR PRO is a smart WiFi device. It is equipped with a lightweight power management module, ample USB interfaces, and multiple dovetail mounting methods.
With the rich features of the ASIAIR App, the whole procedure from device integration to image capture runs particularly smooth.
ASIAIR PRO is the second generation of ZWO that has been continuously improved and newly designed since the first generation of ASIAIR was released in July 2018.
Outstanding Features
1. Excellent craftsmanship, strong tactile appeal
Superb craftsmanship with a strong tactile appeal ASIAIR PRO shell is made out of aluminum and processed by CNC tech. After the surface is anodized, it not only protects the shell well, but also has a comfortable feel. The size of the whole machine is 92 x 67 x 35 mm, making its size and weight excellent, which can be easily grasped by hand.
2. Unique look and easy installation
The slot/port position of ASIAIR PRO is nice and symmetrical, with M4 and 1/4 inch openings on the bottom and the side. With the use of the dovetail, the installation and removal become easy. The whole machine adopts bright vibrant Ferrari red tones, and the front is painted with laser star maps of the constellation Ursa Minor and Ursa Major, which is very beautiful.
3. Integrated power management, more storage space
ASIAIR PRO is equipped with a lightweight power management module. There are four DC 5.5 x 2.1 mm power outputs on the side of the body, one DSLR shutter release port, two USB 2.0 and USB 3.0 ports each. The power supply is stable and reliable, the interface is rich and diverse, and the wiring is easy and orderly. It also comes with 86 GB of storage, so you can capture images freely.
4. LED indicator, clearly indicates the working status
The LEDs will show the working status clearly. What’s more, it has the key operation warning tone, which makes the whole operation under control.
App Functions
ASIAIR supports both iOS and Android systems.
1. Simple APP interface, as easy as 1, 2, 3.
2. Accurate focus: After the rough focus is completed, select one star, then accurate focusing can be done through curves such as brightness and HFD. It can also be completed with ZWO EAF by remote control.
3. Polar Alignment: Based on the powerful plate-solving function, you can finish arc-second polar axis alignment only within few minutes.
4. Accurate GoTo: With the rich celestial object database, precise GoTo can be achieved after selecting the target.
5. Stable guiding: Independent and stable guiding can be achieved without the PC.
6. Preview mode: You can see the image of the target directly under ‘Preview’.
7. Autorun: Set the target and configure the schedule, ASIAIR will execute the imaging sequence automatically.
8. Live Stacking: You can see the stacked image (lower noise with calibration frames) of the target directly while capturing.
Supported DSLR
ASIAIR PRO is a smart WiFi device that allows you to control all ASI USB 3.0 cameras, ASI Mini series cameras, and Mainstream DSLR cameras. (It can not support ASI120MM/MC camera)
Note:
1. Some DSLR cameras have a 30-second exposure limit, which requires an external shutter release cable to ASIAIR PRO.
2. The items with an exclamation mark in the table above have not been verified by actual tests and will be continuously updated in the future.
Supported Mount
We have also been working closely with major manufacturers to complete bringing in the match of iOptron, Vixen, Rainbow, Avalon, Explore Scientific and other models (including some new models). For now, the ASIAIR PRO is able to support hundreds of equatorial mounts from more than 20 manufacturers worldwide. For details, please refer to the “ASIAIR PRO User Manual”.
What is in the box?
DC male 1m cable x 2
ASIAIR Pro body
64GB U disk
DC 1.5m male and female cable extension cable
DC male 0.5 m cable x2
Quick Guide
USB-RS232 female covert cable
USB 3.0 square port 0.75m data cable
Note:
Neither USB flash drive nor TF card is covered by Warranty Policy.
About ZWO ASIAIR PRO [ZWO-ASIAIR-PRO]
App Functions
Supported DSLR
Note:
Supported Mount
What is in the box?
ASIAIR Pro body
64GB U disk
Quick Guide
Note:
