ZWO ASI120MM Mini Monochrome astronomy camera. [ZWO-ASI120MINI]
ZWO-ASI120MINI
$149.00 USD
ZWO Optical: ASI120MM Mini camera integrates AR0130CS 1/3″ sensor (4.8 mm x 3.6 mm). It is ZWO new mini camera. This camera has 1280 x 960 pixels. The pixel size is 3.75 μm x 3.75 μm.  This camera provides 12bit ADC and its QE peak is almost 80%.
Astrophotography Performance
ASI120 mini camera offers you very good performance for planetary imaging and guiding. Low read noise, high dynamic range,  AR protective window and much more. Absolute QE Curve, we estimate the Peak Value is almost 80%.
120Mini VS 120MM-S
Compared with ASI120MM-S camera, 120mini have smaller outlook, lighter weight, and it can reach focus at same position with eyepiece.
USB 2.0 Port: Mini camera has one USB2.0 type C port. Type C port is very popular in mobile phones, it will not care about positive side and negetive side of the adapter.
ST4 Port: Can connect mini camera direct connect to auto guide port of mount.
ASI290 mini is designed for precisely guiding. 2.9um pixel size can give you a higher arcsec/pixel than 224 or 120 camera. Which means in same guide scope, 290mini can detective slighter movement of stars. ASI290 mini can improve about 30% guide precision than 120mm. ASI mini camera can focus at same position as eyepiece. You can focus with a eyepiece, and put ASI mini camera into 1.25″ holder.
Mini camera is very suitable for OAG, it has much biger focus range than normal ASI cameras. Never to worry about that guide camera can not focus with main camera at same time.
What is in the box?
ASI mini camera box includes all necessary cables, adapters, and manuals.
About ZWO ASI120MM Mini Monochrome astronomy camera. [ZWO-ASI120MINI]
120Mini VS 120MM-S
What is in the box?
  • Sensor: 1/3″ CMOS AR0130CS(Mono)
  • Resolution: 1.2Mega Pixels 1280×960
  • Pixel Size: 3.75µm
  • Exposure Range: 64µs-2000s
  • ROI: Supported
  • ST4 Guider Port: Yes
  • Focus Distance to Sensor: 8.5mm
  • Shutter Type: Rolling Shutter
  • Protect window: AR coated window
  • Operating System Compatibility: Mac, Windows, Linux
  • Interface: USB2.0
  • Bit rate: 12bit output
  • Adaptor:1.25″ / M28.5X0.6
  • Dimension: φ36mm X 61mm
  • Weight: 60g or 3.1 ounces (without lens)
  • Working Temperature: -5°C—45°C
  • Storage Temperature: -20°C—60°C
  • Working Relative Humidity: 20%—80%
  • Storage Relative Humidity: 20%—95%
  • Supported resolution
Binning 1×1:
  • 1280X960@35FPS
  • 1280X720@46FPS
  • 1024X768@54FPS
  • 800X600@90FPS
  • 640X480@118FPS
  • 320X240@224FPS
Binning 2×2:
  • 640X480@35FP
More resolutions can be user defined
