ZWO ASI183MM Monochrome astronomy camera [ZWO-ASI183MM]
ZWO-ASI183MM
$699.00 USD
ZWO Optical: Introducing the ASI183 camera series, the most sensitivie cameras in ZWO history. Peak Q.E. of the mono sensor reaches 84%!
IMX183CLK-J/CQJ-J
Diagonal 15.86 mm Approx. 20.48M-Effective Pixel Monochrome/Color CMOS Image Sensor
IMX183CQJ-4K-Sensor
High-Speed and High-Picture-Quality Rolling Shutter-Type Back-Illuminated CMOS Image Sensors
In the astronomic application field, Sony IMX183CLK-J (monochrome) and IMX183CQJ-J (color) sensors uses a very high sensitivity back-illuminated structure with high resolution 2.4 μm square unit pixel.  The optical size is 1 inch.
Astrophotography Performance
The ASI183 cameras has a very large full well capacity(15000e) for such small pixel size, 1.6e read noise @ 30DB, and 12stops dynamic range @ Gain=0. The ASI183 cameras also utilize firmware features to minimize amplifier glow for maximum performance in astrophotography.
High Speed
Fast FPS can be used in solar and lunar imaging, as well as for live viewing/EAA.The high speed readout may also be used for real-time focusing, true lucky imaging of double stars and other small objects, planetary imaging of the major planets in the solar system, and much more.
10Bit ADC
5496×3672    19fps
3840×2160    41.04fps
1920×1080    80.10fps
1280×720      117.30fps
12bit ADC
5496×3672    19fps
3840×2160    36.12fps
1920×1080    70.48fps
1280×720      103.23fps
High QE
Sony’s back-illuminated Exmor R technology, giving it excellent Deep Sky performance. ASI183 QE peak reaches a remarkable 84%. In Ha channel, QE is still a over 60%.
Having high QE means more of the light that enters your telescope and reaches the sensor is actually used. With 84% peak Q.E. and no less than ~50% within the visible spectrum, the ASI183 will utilize a high percentage of the light that reaches it, improving your signal quality.
USB 3.0 Port & ST4 Port
USB 3.0 Port: Provide 5Gb bandwidth to make it possible for ASI183 to run at 19 fps (12bit, normal mode) or 19 fps (10bit, high speed mode)  at full resolution(20.18Mega).
ST4 Port: can be used connect with auto guide port of mount, for guiding
What is in the box?
ASI183 box includes all necessary cables, adapters, and manuals.
About ZWO ASI183MM Monochrome astronomy camera [ZWO-ASI183MM]
IMX183CLK-J/CQJ-J
IMX183CQJ-4K-Sensor
High Speed
10Bit ADC
5496×3672    19fps
3840×2160    41.04fps
1920×1080    80.10fps
1280×720      117.30fps
12bit ADC
5496×3672    19fps
3840×2160    36.12fps
1920×1080    70.48fps
1280×720      103.23fps
High QE
What is in the box?
  • Sensor: 1″ CMOS IMX183CLK-J/CQJ-J
  • Diagonal: 15.9mm
  • Resolution: 20.18Mega Pixels 5496*3672
  • Pixel Size: 2.4μm
  • Bayer Pattern: None
  • Shutter:Rolling shutter
  • Exposure Range: 32µs-2000s
  • ROI: Supported
  • ST4 Guider Port: Yes
  • Read Noise: 1.6e @30db gain
  • QE peak: 84%
  • Full well: 15ke
  • ADC:12bit
  • Interface: USB3.0/USB2.0
  • Adaptor: 2″ / 1.25″ / M42X0.75
  • Dimension: φ62mm X 36mm
  • Weight: 120g or 4.2 ounces (without lens)
  • Working Temperature: -5°C—45°C
  • Storage Temperature: -20°C—60°C
  • Working Relative Humidity: 20%—80%
  • Storage Relative Humidity: 20%—95%
  • Max FPS at full resolution:
  • 10Bit ADC
  • 5496×3672 19fps
  • 3840×2160 41.04fps
  • 1920×1080 80.10fps
  • 1280×720 117.30fps
  • 640×480 169.92fps
  • 320×240 308.17fps
  • 12bit ADC
  • 5496×3672 19fps
  • 3840×2160 36.12fps
  • 1920×1080 70.48fps
  • 1280×720 103.23fps
  • 640×480 149.53fps
  • 320×240 271.19fps
