Takahashi TOA-150B Refractor Telescope [TK-TOK15110]
TK-TOK15110
$15,080.00 USD
Get a FREE TOA 35 Flattener with the purchase of any TOA-130 or TOA-150 Optical Tube Assembly until December 31st 2019 (until quantities last)
Takahashi America: The TOA series is a member of Takahashi’s line of triplet refractors.  In the TOA design, three lens elements are used, with the front and rear constructed from ED glass.  The resulting system achieves a high level of apochromatic performance for both visual observation and imaging.  Takahashi engineers have a undertaken a complete redesign of the triplet system, completely eliminating spherical aberration while minimizing axial chromatic aberration in the visible light spectrum.
In typical apochromatic designs, the elimination of chromatic aberration is usually at the expense of increasing spherical aberration at various wavelengths.  However, with the TOA series, the focal shift across the entire visible spectrum from 436 nm up to 656 nm is less than +/- 0.01 mm.  This is less than 1/100 the aberration of a typical apochromatic design.
TOA-150B
The TOA-150B is a 150 mm apochromatic f/7.3 refractor with a focal length of 1100 mm.  It features a retractable lens hood, a 4 inch rack and pinion focuser with a 7:1 fine focuser, and a 360 degree camera angle adjuster.  A complete line of flatteners, reducers and extenders are available, including the 67-series flattener, which provides a 90 mm imaging circle.
A tube weight is standard to assist in balancing instrumentation or visual accessories.
Optical tube only.  Mount and tripod sold separately.
About Takahashi TOA-150B Refractor Telescope [TK-TOK15110]
TOA-150B
  • Code TOK15110
  • SKU TOK15110
  • Weight 40370
  • Size X 124
  • Size Y 38
  • Size Z 50
  • FREE - [zx] Large/heavy - contact us for cost (Contact us)
