William Optics Zenithstar 61 APO - BLUE [WO-A-Z61BU]
WO-A-Z61BU
$471.59 USD
William Optics: The Zenithstar 61 is designed for both daytime and nighttime viewing, as an outstanding travel scope. We recommend purchasing a WO 2” star diagonal to make the most of these little telescopes.
Since the Zenithstar 61 is well suited to viewing nebulae, clusters, large galaxies, andcomets, we recommend the use of high-quality wide-angle eyepieces. The WO SWAN, XWA, and SPL series eyepieces are available in a variety of focal lengths. Viewing the moon and planets is also impressive at magnifications of 120X when the seeing conditions permit.
To calculate the magnification of your telescope and eyepiece combination, divide the telescope focal length in mm by the eyepiece focal length in mm.
Keep in mind that the atmosphere plays an important role in seeing conditions, and only the best-seeing conditions will support high power viewing. Additional power under less than ideal seeing conditions will not result in an increase in viewable details, and lower powered eyepieces should there be used under those conditions. It’s easiest to locate objects using low-power eyepieces (20X magnification) and then zoom in by switching to higher powered eyepieces. The largest field of view will be seen using a 12x low power-wide field of view eyepiece.
A stable tripod or mount is recommended for optimal viewing. This includes high-quality photography tripods, and German Equatorial mounts, which are designed for astronomical use and include precise tracking of celestial objects. Optional accessories from WO include mounting rings and plates, super high quality 2” Quartz star diagonals which provide for superior viewing and high-quality images.
The Zenithstar Telescopes are suitable for large-field astrophotography; Zenithstar 61 has a great color correction at a fast speed of f5.9.
About William Optics Zenithstar 61 APO - BLUE [WO-A-Z61BU]
  • Aperture 61mm
  • Focal Ratio F/5.9
  • Focal Length 360 mm
  • Limiting
  • Magnitude 10
  • Image Circle Z61 Φ 41mm / Z61 with Flat 6 Φ 43mm
  • Objective
  • Type
  • Synthetic Flourite FPL 53 Doublet, Air Spaced, APO
  • Fully Multi-Coated, SMC coating.
  • Lens Shade Retractable
  • Focuser 50.8mm(2”) R&P Focuser
  • with 1:10 Dual Speed micro focuser
  • 75 mm Focuser Travel Length
  • Field Stops Baffles
  • Type of mount Rotatable L Bracket
  • Diameters Main Tube Diameter 75 mm / Dewshield Diameter 80mm
  • Tube Length 230 mm Fully Retracted
  • 300 mm Fully Extended
  • Tube Weight 1.45kg
