Parallax 10.3" OD Tubes (Celestron C-9.25) [PA-ODT103]
These 10.3" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 10.3" OD Tubes (Celestron C-9.25) [PA-ODT103]
Parallax Instruments: Parallax - 10.3" OD Tube Rings (Celestron C-9.25)
