Parallax 11" OD Tubes [PA-ODT11]
PA-ODT11
$306.80 USD
Parallax Instruments: Parallax - 11" OD Tube Rings
These 11" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 11" OD Tubes [PA-ODT11]
