Parallax 11.63" OD Tube (Meade 10" SCT, Meade SN-10 Newtonian) [PA-ODT1163]
These 11.63" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 11.63" OD Tube (Meade 10" SCT, Meade SN-10 Newtonian) [PA-ODT1163]
Parallax Instruments: Parallax -11.63" OD Tube (Meade 10" SCT, Meade SN-10 Newtonian)
