Parallax 11.69" OD Tubes (AT 10 RC) [PA-ODT1169]
These 11.69" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 11.69" OD Tubes (AT 10 RC) [PA-ODT1169]
Parallax Instruments: Parallax -11.69" OD Tubes (AT 10 RC)
