Parallax 11.75" OD Tubes (Meade 10" SCT, Deep Sky Instruments RC-10) [PA-ODT1175]
These 11.75" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 11.75" OD Tubes (Meade 10" SCT, Deep Sky Instruments RC-10) [PA-ODT1175]
Parallax Instruments: Parallax - 11.75 OD Tube Rings (Meade 10" SCT, Deep Sky Instruments RC-10)
