Parallax 12" OD Tubes (Celestron C-11, Vixen 260) [PA-ODT12]
These 12" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 12" OD Tubes (Celestron C-11, Vixen 260) [PA-ODT12]
Parallax Instruments: Parallax - 12" OD Tube Rings (Celestron C-11, Parks 10" Newtonian, Meade 10" SCT)
