Parallax 12" OD Extra Heavy Duty Tube Rings for 10"-12" Refractors [PA-ODT12HD]
PA-ODT12HD
$497.60 USD
Parallax Instruments: Parallax - 12" OD Extra Heavy Duty Tube Rings for 10"-12" Refractors
These 12" outside diameter split tube rings are made of extra heavy die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 12" OD Extra Heavy Duty Tube Rings for 10"-12" Refractors [PA-ODT12HD]
