Parallax 12.7" OD Tubes (Meade 10" Starfinder) [PA-ODT127]
These 12.7" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 12.7" OD Tubes (Meade 10" Starfinder) [PA-ODT127]
Parallax Instruments: Parallax - 12.7" OD Tube Rings (Meade 10" Starfinder)
