Parallax 13.6" OD Tubes (Meade 12" SCT) [PA-ODT136]
PA-ODT136
$328.00 USD
Parallax Instruments: Parallax - 13.6" OD Tube Rings (Meade 12" SCT)
These 13.6" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 13.6" OD Tubes (Meade 12" SCT) [PA-ODT136]
