Parallax 14.17" OD Tubes (AT 12 RC) [PA-ODT1417]
These 14.17" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 14.17" OD Tubes (AT 12 RC) [PA-ODT1417]
Parallax Instruments: Parallax - 14.17" (AT 12 RC)" OD Tube Rings
