Parallax 15.7" OD Tubes (MEADE 14" SCT) [PA-ODT157]
These 15.7" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 15.7" OD Tubes (MEADE 14" SCT) [PA-ODT157]
Parallax Instruments: Parallax - 15.7" OD Tube Rings (Meade 14" SCT)
